Freezer works no refrigerator,maytag
Most common fault to cause this problem is cooling element in freezer section iced up. could also be faulty fridge stat not letting cold air through.first pull drawers out of freezer section, if back cover inside feels frosty or snowy, then likely evap (cooling element) is iced up.if so empty cab, switch off for 24 hours with both doors open, and restart. ice ups can be the result of the freezer door being left ajar, but can also be a problem with auto defrost as well as problem in refrigeration circuit. if problem comes back call a service engineer.
The defrost is not working and the fan is hitting ice buildup...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
