Master
- Posted on Feb 27, 2010
Re: Husky 254 xp spark from plug but will not start plug...
If the plug is wet the saw is flooded. Try the following to clear that condition.
Extreme Flooding by Dolfoff; Please follow this link,
http://www.fixya.com/support/t3226410
cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button.
Once the flooding condition is cleared this start procedure works for every saw I have (7). Please read line 3 twice; both cold and warm.
Start Procedure
Cold:
- Ignition on/off to on
- Set compression release – optional step even if saw is equipped with a compression release
- Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
- Push (open) choke pull starter until it starts. (usually first pull)
Warm:
- Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
- Push (open) choke, pull starter until it starts. (usually first pull)
Good Luck. HTH
Lou
