Smeg S1100MFX5 Electric Single Oven Logo
Posted on Feb 26, 2010
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
  • Joanne mulholland May 30, 2021
    Please give me the symbols of the right side temp knob as mine rubbed off years ago & I want to use my oven again
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16911
Points
9
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
  • 1 more comment
  • Anonymous Jun 01, 2010
    Oooppps..here's the piccy!
  • Anonymous Dec 31, 2011
    Hey! I need to connect the wires on the new selector switch of the same electric oven, but I dont know how because the original is burned out... help me please. Send me a picture (if it is possible). Thank you!
  • Anonymous Jul 11, 2013
    can you please tell me what those symbols mean? I'm house sitting and burnt my first batch of cupcakes rather severely!
Fixed fan element, but can't remember how to put it back together again
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jun 22, 2012 • Smeg Ovens
2helpful
2answers
Symbols around dial of electric cooker have been rubbed out. Can I purchase new stick on ones?
Well, they don't sell stickers anymore but u could buy graffix art stickers numbers that are in different sizes and u could do it by urself!
When sticking those numbers, try to buy the CLEAR COAT paste spray, use by artist and architects, spray it on those stickers to have them laminated for life! Hope that helps u out!
Nov 18, 2010 • Ovens
Symbols have rubbed off for the Smeg SA708 oven
I Have The Same Problem Have You Managed To Work Yours Out??
18helpful
3answers
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
4helpful
4answers
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
2helpful
SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Top Smeg Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Paul Carew
Are you a Smeg Oven Expert? Answer questions, earn points and help others
