Sony VAIO VGN-FW270J/W 16.4-Inch Widescreen Notebook PC (2.26GHz Intel Core 2 Duo Processor P8400, 4 Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power switch on my vaio fw-270j is broken. Can this be replaced?
Anonymous
Level 2:
Scholar:
  • Expert 154 Answers
  • Posted on Apr 10, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
154
Questions
0
Helped
68304
Points
248
Yes, you can call sony to check if it is still part of the warranty.. they will send a tech to fix your computer
sony tech support 888-476-6972 or 239 768 7669
My original charger got spoilt,so i got a replacement which blowed my computer. a technician recomended a new mother board
There maybe a fuse on the motherboard in the power supply circuit.
That would be a quick check to save putting in a new motherboard.
If you're not a technician, I would not attempt.
Board level repair or replacement would be the only solution.
You could also find the exact model Sony WAIO and swap the HDD.
My problem is driving me crazy! I have a Sony Vaio FW 400 series. I switch my machine on, the green power light comes on, it then flashes orange and the machine goes off, then it comes back on...
Kindly try the following...
- remove the battery and power on the laptop using power cable.
- issue not fixed.. remove the power cable and make sure you have not installed the battery ...then press and hold the power button for 30 sec.. then check at the bottom of the laptop if you have access to memory card if so try to open the back cover and reset the memory card and check.
-issue not fixed.. if you have access to the wifi card try and reset the wifi card and check
-if the memory card and wifi card is inaccessible then you will need to visit service center or call support
2helpful
2answers
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
5helpful
2answers
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
My Sony VAIO's wireless switch doesnt wanna work...When I turn it on the Wi-Fi program comes up but the computer cant get conected to the internet and the light next to the bottom stays off...what shoud I...
Try to go to another place where there is free WIFI like Starbucks or similar place.
If the computer can connect there, the the problem is with the WEP KEY on your modem/router. You need to update this key on your computer's wireless connections.
We need to know what operating systems do you have and what kind of modem/router do you have to help you more.
When switching on laptop it comes on but nothing
it is just fault in ur lcd belt......... just check it out nd rply.........
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
