The eMachines W2828 uses an MSI MS-7061 motherboard. Also known as KM3M-V.
This is MSI Support, and the download page for the KM3M-V motherboard manual,
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=590Left-click on the blue - M7061v1.2.zip - file name under the Download heading.
On the next page click on the country nearest yours.
A small window will come up.
Be sure the empty circle to the left of Save File, has a green dot in it.
If not, Left-click in the empty circle.
Now go below, and click on OK.
This is a Zip file. Zip files are used to send a large amount of information. The file is condensed.
If you do not have your downloads set to save to your My Documents folder, (Could also go to a sub-folder in My Documents>Downloads), this file will go to your desktop screen.
When you see the file name - M7061v1.2.zip, double-click right on it.
On the left side of the screen go up to the top, and left-click on - Extract All Files.
Follow the instructions of the Unzip Wizard.
Barring you have trouble downloading, or opening the file;
Orient the motherboard so the Processor is at the top, and Ram Memory slots are to the right.
Below the CMOS battery is a front panel header > JFP1
(Front Panel is the plastic front part of the computer, the Power On switch, Power On LED, and HDD LED are located)
There are three white PCI slots on the motherboard, below the Processor socket.
The last PCI slot that is closest to the outside edge of the motherboard, is PCI 3.
Below the PCI 3 slot is the AUD1 header. (Audio 1)
Below the right corner of the PCI 3 slot are two more headers.
JUSB1, and JUSB2
These two headers are combined together.
To the right of the JUSB1 and JUSB2 headers is another header.
JFP2.
To the right of the JFP2 header is a header that only has two pins.
JC11.
To the right of the JC11 header is the JFP1 header.
It is the last horizontal header, and is all the way to the right of the motherboard.
The JFP1 header is parallel to the outside edge of the motherboard.
There are two rows of pins.
Four across the top, then a blank space. (Or no pin)
Five across the bottom.
The pins going across the top of the JFP1 header are numbered Evenly.
Starting at the Left side going towards the right, the pins are numbered 2, 4, 6, 8, and 10.
There is NO pin 10, however
The pins going across the bottom are numbered Odd.
Starting at the Left side going towards the right, the pins are numbered,
1, 3, 5, 7, and 9.
1) Pins 2 and 4 are for the Power LED lamp.
2) Pins 6 and 8 are for the Power On switch
3) Pins 1 and 3 are for the HarDDrive activity LED
4) Pins 5 and 7 are for the Reset switch
