could be bad solinoid, only letting water to dispencer, u could switch sol leades to see if water goes to ice maker, but check ti make icemaker is on first
If this is your water dispenser leaking Your water inlet valve on the back where the
water supply comes in is probably leaking. disconnect the water line coming out
of it and see if you have a slow drip. Try the dispenser to see if it's just
drips after use.
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
There could be a number of problems. Some ways to try to find the problem would be to check and see if there is ice in the icemaker which would mean there is probably something wrong with the mechanism that empties the trays. Or if there isnt any ice, there there is something wrong with the water dispensing system. If you can figure either of those things out it would help in figuring out how to fix it.
HAVE YOU CHECKED YOUR WATER VALVE LOCATED AT THE BACK BOTTOM RIGHT OF THE APPLIANCE THAT MIGHT BE THE CAUSE OF THE ICE MAKER NOT WORKING.LET ME KNOW IF YOU REQUIR FURTHER ASSISTANCE.GOODLUCK.MOHAMED
