There should have been a sheet or book of bar codes that came with your scanner. These codes will allow you to program your scanner to do most anything, including adding a tab. You simply look at the bar codes and read what they do. you simply scan the one that adds a tab and it will forever add the tab unless you re program it.
If you have lost your book/bar code page, you should be able to go to the manufacturer website and download/print a document with the programmable bar codes.
Here is what I did to fix the problem of the bar-code scanner not going
to next line after a successful scan. (Symbol ls4000i,This fix should
work for other models as well)
1. Get the manual for your scanner or here is a link to the Symbol LS400i
https://docs.symbol.com/manuals/3789802a.pdf
You will want to print off few pages that have the proper bar-codes for programming.
2. I usually start with setting scanner to the Default Parameter, this should be in section 5-7,page 50 of the manual.PRINT IT
Warning!
If you set scanner to default, you need to be aware of which bar-code
types you use. (We use UPC-A) Also if you have it programed for other
things already you may not want to set all settings to default. You can
skip to step 4. If you do not wish to reset all values to default.
Now scan the Default bar-code.
3. Now program scanner to Enable your bar-code type. (For us Enable UPC-A bar-code is in section 5-22,page 66. PRINT IT
Now Scan the Enable (your bar-code type UPC-A, UPC-E,etc etc)
4.Next You need to set a Suffix Value. The scan Suffix bar-code is found in section 5-80, page 124. PRINT IT
Now Scan the Scan Suffix bar-code
This prepares the scanner for the code of the whatever Suffix you want to add.
5.
The Suffix you want to add to fix this particular problem is ENTER. So
that it goes to the next line. There is a prefix/suffix value chart on
page 162 table A-4. The code for ENTER Is 7013. In order to enter this
code you will need to print off the Numeric Bar Codes found in section
5-109,5-110,pages 153,154. PRINT IT
Now scan in 7013 one number at a time to program ENTER as the suffix.
6.Now you have to program the Scan Data Transmission Format found in section 5-81,5-82, pages 125,126 . PRINT IT
(This lets the scanner know to transmit the Suffix after the data.)
First scan the Scan Options Bar-code.
Second scan the <DATA><SUFFIX> bar-code.
Last scan the ENTER Bar-Code.
YOUR DONE !
Your
scanner should be working now. Also look through the manual there are
some nice functions that can be turned on and off with a simple bar code
scan. Such as volume and tone of beep etc etc.
Hope this helps
Nate N7w7
