Hi, how do I re-install my device drivers. Im a novice when it comes to computors, but determined to learn.Hi, how do I re-install my device drivers. Im a novice when it comes to computors, but determined to learn.
You can't post conmments that contain an email address.
It may sound stupid, but some people do not know that deleted messages are stored in the recycle bin . Click on Start ' Help and support and you should find version specific info for your version of windows ( just enter recycle bin in the search box). If you have already emptied the recycle bin , google active software and try their unerase application.
You have probably got the bin so full it is stuck/jammed full of paper and you now can't remove it...this is a "consumer" model machine and to keep cost low they do not provide a "bag-full" light on the panel...you should regularly empty the bin so that the shredded paper does not totally jam the bin and in extreme cases then get caught back up into the cutting machanism and blow the pcb inside the machine...check your "users" instructions to remove the bin.
normally someone has removed the bin to empty the ice or it was pulled out a little by accident. Try removing the bin and make sure that no ice is jaming the auger motor try turning the auger by hand. Hold down on the door switch and have someone push the demand buttom for ice and see if the motor turns. If it does reinstall bin. If it doesnt make sure ice has not blocked it. reinstall bin and try the ice button. hope this helps if this doesnt fix it the drive motor has went out.
You've lost/deleted your sound drivers. You can usually go to the manufacturer's website (DELL, Gateway, Emachines...) and they will have a free download for your model number. If not, you can usually get by installing a generic audio driver like Realtek AC97 drivers. Google and you should find plenty of download sites...
Good Luck
in device manager
if you see the driver click to update or install
if you can't see it then in add hardware
click audio or sound
follow instructions a box may appear showing the device if so hight light and next if not then
choose option yes to automaticcally install
also you could shut down and remove audio card restart shutdown again reinstall card the startup again the add hardware should automatically install
but i would do this unless it was absolutely neccesary
The audio driver should be on the install disc and if not go to the asus site and download it and reinstall it.Toy may also want to look in your recycle bin if you have not emptied it . http://www.new-drivers.com/files/sound/?gclid=CL-_i7uv-ZUCFQQRswodVHSXFg
download these FREE programs and run them, following the instructions. Ccleaner, spybot 1.52 & ad-aware 2008 free, if you are using XP, before running the programs 1) empty bin. then right click on the icon and go to properties and reduce size to zero. 2) go to "control panel", "system", and select "system restore" tab. turn off system restore
