Dear Sir, My daewoo microoven KOR 860A one year old. Its not getting heated where as motor timer and other things are working ok. For normal heating purposes Which auto cook mode to select( AC1 or Ac2 or Ac3...). Water even after 5 min is not getting heated (fully cold) Advance Thanks for your immediate response. my email id:[email protected]
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
If only the start button is inactive but you are able to set timing then then the start button pad must be worn out.
