I have ATT u-verse remote, but I don't have code to control new Hannspree 32inch lcd tv. Can you help?
I also had this problem. I talked to an AT&T technical support guy over the phone yesterday, and he told me some weird instructions. The TV was responsive to the controller but we couldn't get it to work. About an hour ago I called Hannspree technical support and they told me codes to control my AT&T receiver with their remote. I just tried the codes for my AT&T U-verse remote, just to see if they would work anyhow, AND THEY DID! Unfortunately, the codes will control the TV entirely, except turning it on.... (it does turn it off though) If these codes are of any use to you, they are:
1004 and 1018
try the first one, and if doesn't work, try the second one. If you are new to the AT&T U-verse world, these are the instructions:
*Turn on your TV first
1)Hold the TV button on the AT&T remote
2)While holding, hold the OK button
3)Now release both of them
4)All the mode buttons while now flash twice
(You will now have 6 seconds to do step 5, if not they will do a long flash, indicating to start over)
5)Now, quickly, type in the combination (in this case, 1004, or 1018)
6)The TV button will flash 3 times if it works, or a long flash if it doesn't
7)Now point the remote to the TV and press Power. If it turns off, IT WORKED!
*Remember, these codes are the only codes I know of and they took forever to find, and they aren't supposed to work with the AT&T U-verse remote, but they did. The only defect is you can't turn ON the TV with the AT&T U-verse remote, but you can do everything else (YOU CAN TURN IT OFF)
Hope this helps!!!!
