I have a lemax gondola ride as well and the problem seems to be the weight of the gondolas tends to pull the cable off of the drive units to which they are attached. If you have ever looked at BRAWA BR6280
set there is a tower in the middle of the setup that allows for holding
the cable in elevated position as it goes around. You might need to construct a tower with a couple of reels on it (someone suggested
using the reels out of a audio casette) for the cable to travel around/on
Could try and see if that helps.....
