Hi Model SHV55M03GB. Items in top tray are not cleaning properly. The top spinning arm is not revolving. Have checked filters and feed pipe to spinner. Spinner revolves freely.
Remove the upper wash arm from the rack. Examine thoroughly. Look for hair line cracks especially if the wash arm is plastic. Top rack wash arms have spray holes on the top AND bottom. Check both places. Sometimes small fish bones will clog the hallway of wash arm not just the holes. After years of use, the wash arm will bow especially plastic ones. Be sure the water connection to wash arm is Secure. If you think the wash arm is not spinning, try this. Place a old cell phone inside a sealed glass jar and start recording video from the lower rack. Be sure jar is Secure. The light from phone will come on. You might see the problem this way.
Hello ezideas - First I suggest verifying that there is enough water pressure coming into the unit and that it is at least 120F. Do you noticed if the spray arm will rotate freely or if it is damaged? If so, the spray arm assembly may need to be replaced. Connect with a professional to accurately pinpoint any potentially more serious issue.
The most likely answer is that your upper rotor spray arm isn't spinning or spraying water. They aren't powered by a motor - they are driven by water pressure. The most common reason for them not spinning is a blockage somewhere. The lower rotor arm is spraying dirt from the plates in the lower rack onto the glassware and there is no spray from the upper rotor arm to rinse it off.
Check the small spray holes on the top of the upper rotor arm. If they are blocked, use a large pin or a cocktail stick to clean them out. If they aren't blocked, check to see whether the upper rotor arm is spinning by following these steps:
1. Note the exact position of the upper spray arm or spin it so that it is running precisely left to right or front to back 2. Close the door 3. Start any wash cycle 4 After it has finished filling with water and starting cycling the water, open the door and note the position of the upper spray arm again.
If the spray arm is in the exact same position as when you closed the door it's almost definite that it's not spinning. In this event, cancel the wash and do the above test one more time just to eliminate the element of pure chance.
Try the above tests and checks and then post back with the results if you need any further assistance. If posting back, please include the full model number of your Frigidaire dishwasher
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
When my wife started complaining about her dishwasher not getting the top rack
clean this is what I found and I wrote a tip about it...
Possible causes of spray arm inefficiency: Loading large or tall items in the lower basket which stops the arm revolving. Upper spray arm split along seam. Upper spray arm blocked. Under dosing of powder causing foam and reducing upper spray arm water pressure. Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure. inefficient wash motor impellor (faulty)
Check to see if the top rack wash arm water fitting is mating with the outlet on the back inside of the machine and the spinning was arm. This fitting can become displaced causing the water from the pump to just spray out into the washer and not clean the dishes on the top rack. it's usually just a matter of re-positioning the fitting and making sure it's connected to the top rack spinning wash manifold.
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
only the top rack isnt getting clean? there is a little plastic
circle in the middle of the bottom of the upper spray arm. turn it
counter clock wise to pull the upper spray arm from the upper rack.
make sure that isnt clogged and the spray holes are not clogged.
otherwise....
the piece that the bottem spray arm plugs into and
runs along the back wall of the tank to the top is called a feed tube.
pull the bottom spray arm out. now you can see the part of the feed
tube that feeds the upper spray arm water. does it pop out freely and
easily? if so then you need a new feed tube, if not then its most
likely your not achieving the right water level or your impeller
connected to your circulation pump(motor) is clogged not supplying
enough water pressure to travel up the feed tube to spin the upper
spray arm.
