Toshiba REGZA 52RV530U LCD TV Logo
Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Full tv screen is not being diplayed horzontally.
Anonymous
Level 3:
  • Master 350 Answers
  • Posted on Feb 24, 2010
Anonymous
Master
Level 3:
Answers
350
Questions
0
Helped
137525
Points
1214
First thing to check is the picture size. You can view many program formats in a variety of picture sizes
  1. Natural
  2. TheaterWide 1
  3. TheaterWide 2
  4. TheaterWide 3
  5. Full
  6. 4:3 HD
  7. Native
  8. Dot by Dot.
The format of the image will vary depending on the format of the signal you are currently watching from you cable or satellite provider. Select the picture size that displays the current program the way that looks best to you.
To select the picture size using the remote control:
  1. Press I on the remote control.
  2. While the Picture Size screen is open, you can do one of the following to select your desired picture size:
• Repeatedly press I.
• Press the corresponding Number button (0–6) while the Picture Size screen is open.
• Press B or b while the Picture Size screen is open.
To select the picture size using the menus:
  1. Select Picture Size in the Theater Settings menu.
  2. Press C or c to select the desired picture size setting.
  3. Highlight Done and press T.
Some of the picture sizes may not be available depending on the receiving signal format from your cable or satellite provider (those will be “grayed out” in the Picture Size screen).
Second thing to check is the Native Mode which restores the size of the picture by the 3-5% that is generally lost during the normal over scanning that occurs on traditional sets. It also avoids unnecessary scaling of 1920 x 1080 HD signals. I hope this helps and good luck!
How do I fix vertical lines on my LG tv
mak a lot of horzontal lines 2 even it out
1helpful
Fix. Tv
This line is due to fault to horizontal sweep section. Replace all the non-electrolytic capacitors with new ones. Replace the horzontal output transistor too. Check this linkhttp://electronicshelponline.blogspot.com/ to get more details.
Screen goes out after playing for a few mins
Supply to horizontal supply goes out or horizontal output transistor may got leaky eith respect to its base to emitter. This fault can occur when some turns of deflection yoke's horzontal winding got shorted.
Screen went out, sound works but screen does not. Power on light flashes 7 times on start up
Flyback transformer [LOT] short. Replace the same with similar type and number, and replace the horzontal output transistor alongwith it.
Kv-35xbr48 turns on fine nice picture then horizontal lines form distorting picture like interference also is the back hard to take off and put on needs a good vacum thanks for any suggestion
At first the picture is ok, and then distorted with horizontal lines i thinks. If the horzontal lines are parellel acros the screen, with an inch apart across the whole screen, your tv needs screen adjustments. Screen voltage may be high. look into the crt base also. Change it first. These also not resolve the problem, LOT may be faulty, with respect to screen focus pack. May need replacement. Try first setting screen voltage to a lower settings and observe.
Ther is a white horzontal line in the middle of my tv and i dont hear or see the screen
he white horizontal line with no picture is ususally caused by a failed Flyback transformer in CRT type TV's
repair cost about $200
please rate my help++++Thanks for using FIXYA
Thin horzontal line thru screen
sounds like a pixal went out
3helpful
TV Screen picture reduced to one quarter in size.
You may have a bad capacitor. Do you have horzontal lines near the top? What is the model#? And what year? But ,yes indeed there is a bad cap inside your TV.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
