Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Turn on your printer.
Lift the printer unit, and then position the scanner support
between the tabs to hold it open.
Press down on the ink cartridge lever to raise each ink
cartridge lid.
Remove the old ink cartridges.
Store the cartridges in an air-tight container, such as the
storage unit you received with your photo cartridge, or dispose of them
properly.
If you are installing new ink cartridges, remove the sticker
and transparent tape from the back and bottom of each ink cartridge.
NOTE: The following illustration shows a black cartridge and a
color cartridge (used for normal printing). For photo printing, use a photo
cartridge and a color cartridge.
Snap each lid closed. Hold the printer unit up, push the scanner support back to unlock it, and then
lower the printer unit until it is completely closed.
Insert the new ink cartridges. Make sure the black or photo ink cartridge is
secure in the left ink cartridge carrier, and the color ink cartridge is secure
in the right ink cartridge carrier.
