Some non-Dell batteries will cause the led to flash. There are some aftermarket batteries that have circuitry which 'fools the laptop' and prevents the flashing. As long as the battery is working there's nothing to worry about.
If the batteries were dead for two years it probably will need new ones. The plates get a coating on them making them useless. This is probably why the charger keeps flashing..
I would take note of the message you are getting and buy a new battery. I believe the red flashing lights mean that one or more of the cells in the battery are dying, and it's best not to turn off alarm lights like these. Did the battery hold charge for a longer period than one hour before you started to see the flashing light warning?
Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd. Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
The icons from the left:
1. Power indocator
2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive.
3. Power Source indicator
4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
