Are you in an area with a strong or weak signal? If it's weak, your phone could be going through power trying to repeatedly connect to the network. If you're in an area with a generally strong signal, check to make sure you're not leaving in a "dead zone".
Did you charge it all the way b4 you used it/turned the fone on if this is not done the battery will not be able to set its charge level is is the problem with most batterys its becuase peaple did not charge it the first time Before turning it on also being on the charger longer then it should be will kill your battery so only charge it untill its fully charged
What are you using your phone for? The amount of power the phone consumes differs dramatically depending on how often you use it and if you play games / browse the internet a lot. etc. Try using the phone only for sms' and calls and see if there is a difference.
If the battery is losing power quickly even while the phone isn't being used often / at all, it could be a problem with your phone - and not the battery/charger. I recommend taking it to a repair center / technician to have both the phone and the battery checked out.
It has happened in the past that two batteries in a row are a dud - so it is best to have both checked.
Good luck,
-LL
Testimonial: "thank you for the help i mainly just use it for sms so will have to go get it checked out"
