When i switch my phone on it says no network coverage when the network comes through i cant make or recieve calls or sms's can you help me out with some codes or some thing please
hi...i just updated my n95 from v 12 to v. 20...everythin went well, but i discovered that i cant make calls and SMS...need ur help!hi...i just updated my n95 from v 12 to v. 20...everythin went well, but i discovered that i cant make calls and SMS...need ur help!
my n 95 is new and have only makes two minutes talk and then suddenly lost the network.please help me.my n 95 is new and have only makes two minutes talk and then suddenly lost the network.please help me.
I have an N95, and reside in Jersey, Channel Islands, and am on JT Network, no probs here, but when i go to the uk i cannot recieve or make calls or messages, and cannot manually set the network and recieve "no network coverage !! and have tried everything [good fon savvy] however i put the sim card in the spare "nokia phone" [e61] and all is ok.
help please
SteveHi
help please
Steve
Hi, My N95 was woking fine for the last 2 months. Yesterday it accidently slipped into the water and was submerged for less than 3 seconds when i pulled it out!. It was working fine. However, I now discovered that I don't have the Network Signal on the screen. When I do a manual search for Network, it says, No Network Coverage. I tried my sim on another N95 and it works perfect. I guess there is something wrong with the signal reception. Can anyone help me?? I can be emailed on [email protected]. Hi, My N95 was woking fine for the last 2 months. Yesterday it accidently slipped into the water and was submerged for less than 3 seconds when i pulled it out!. It was working fine. However, I now discovered that I don't have the Network Signal on the screen. When I do a manual search for Network, it says, No Network Coverage. I tried my sim on another N95 and it works perfect. I guess there is something wrong with the signal reception. Can anyone help me?? I can be emailed on [email protected].
AnonymousMar 07, 2009
n95 no network coverage
AnonymousApr 23, 2009
my nokia n95 keeps saying no network coverage,can you help me?
You can't post conmments that contain an email address.
N95 Memory Full Problem can not be resolve by simply restarting or by
changing the network setting. You must "Manual Reset" it. Just Turn Off
the Phone, Press the *, Call Button, Three and ask another Person to
turn on your N95 by pressing the power button. Stay pressing the Three
Buttons until the phone fully boot up and ask you to enter Date and
Time. After that, youre phone will go back to Factory Setting.
Hi, since it is a nokia phone, and on the phone it has service signal bar showing on the screen of the phone, Just apply this codes #33#0000#( to cancel any beared calls(both in and out going calls and #002# ( to cancel any call divert on the phone.
NOTE: it will only work if the service signal bar on the phone the makes you know that there is service on your is full. If not, that means the phone network will be the problem which you will need to consult repairer.
Nokia N95 Cellular Phone Nokia n95 delete data
Help with nokia n95 delete data problem on Nokia N95 Cellular Phone and ... my nokia n95 wont let me turn on loud send messages and recieve them it ... To retrieve all deleted sms from a Nokia N95 handset. Hi, I have a N95 and recently. ... www.fixya.com/...nokia_n95_cellular_phone/nokia_n95_delete_data - Cached
hi, please try to delete some of the files present in the phone memory and restart your phone,,,,,if the problem presists then try reset your phone *#7780# reset to factory settings.....if the problem presists do this C.O.D.E 1: --->>*#7370#or C.O.D.E 2: --->> STEP: 1. Switch off your Nokia Mobile, STEP: 2. Press-> Call button, press-> 3, press-> *, STEP: 3. Now Switch on your Mobile.
If you see my response's to other probs. people are having you will notice they are similar. A lot of what appear to be network issues can be down to 3G probs range from delays sending receiving sms/mms, accessing internet, calls going to voice mail, no signal......
Try changing network mode to GSM 1st, for some reason this can be an issue with the fone trying to use 3G.
hi, Primarily this problem comes due to wrong insertion of message center no, or in rare case software corruption. So call the your network operator and ask them to give the message center no, and insert that no. manually in message settings... Hope this has helped you... Thanks...
I think the problem is your phone has some settings that disabled your SMS functions so I suggest you to try and put your SIM card in another phone and try sendng SMS. If it works, try Reset Settings from the K800i. If it doesn't work, try changing a SIM card from your service provider.
Hi
help please
Steve
