Question about Sanyo VPC-S670 Digital Camera
WHEN I TURN POWER ON IT CUTS BACK OFF SAYING LENS ERROR 1114
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sanyo Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
4 Suggested Answers
6ya staff
SOURCE:
bijudada
Bijen Pandit
  • 16 Answers
SOURCE: Lens Error 1114 the lens won
replace lens unit
Posted on Jul 12, 2009
  • 102366 Answers
SOURCE: lens error 1114 on my camera
Posted on Feb 14, 2010
  • 102366 Answers
SOURCE: Lens Error 1114 the lens won't go back in and it turns off
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
How to correct the lens error 1114
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 03, 2010 | Vivitar VC-7340 Digital Camera
Lens error 1114 on my camera
Jan 07, 2010 | Medion 9653 Digital Camera
Lens error 1114
push the lens in all the way and then turn it back on. it works for me!
Oct 09, 2009 | Cameras
Jun 28, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Lens error 1114
ok if your lans is kinda pointing to one side (like My) you cinda have to pray lol it worked for me love ya god and than you hit your lans to straitin it out and than it will turn on but tha lans still wont go back in so you have to hit it s cupple time down **** so it will go back but not hard dont hit it bck in just kinda lusint it a bit and than turn on the camera and it shuld taike in the lans.
hope i helped
Jul 23, 2008 | Sanyo Xacti VPC-S60 Digital Camera
My Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Sanyo VPC-S670 Digital Camera Logo
123 people viewed this question
Top Sanyo Cameras Experts
Paul Green
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
