I have a Dell GX150 that I have not used in years. I went to turn it on and after the Dell screen loads it states that the computer was improperly shut down last time, in which I can start in safe mode (w/ networking or command prompt), start from last workable state, or Windows normally. If I try normally or from the last workable state it brings on the Windows flag screen and restarts everytime. If I choose any safe mode option it starts to list several file names and then restarts.
I tried Ctrl + F11 to restore, which did not work and I do not have any disc. Is there any way I can get restore Windows or the factory settings? Thanks
Welcome to FixYa!
Using Dell PC Restore by Symantec
Use Dell PC Restore by Symantec only as the last method to restore your operating system. PC
Restore restores your hard drive to the operating state it was in when you purchased the computer.
Any programs or files added since you received your computer-including data files-are
permanently deleted from the hard drive. Data files include documents, spreadsheets, e-mail
messages, digital photos, music files, and so on. If possible, back up all data before using PC
Restore.
NOTICE: Using PC Restore permanently deletes all data on the hard drive and removes any applications
or drivers installed after you received your computer. If possible, back up the data before using PC
Restore.
To use PC Restore:
1 Turn on the computer.
During the boot process, a blue bar with www.dell.com appears at the top of the screen.
2 Immediately upon seeing the blue bar, press .
If you do not press in time, let the computer finish restarting, and then
restart the computer again.
NOTICE: If you do not want to proceed with PC Restore, click Reboot in the following step.
3 On the next screen that appears, click Restore.
4 On the next screen, click Confirm.
The restore process takes approximately 6-10 minutes to complete.
5 When prompted, click Finish to reboot the computer.
NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
6 When prompted, click Yes.
The computer restarts. Because the computer is restored to its original operating state, the
screens that appear, such as the End User License Agreement, are the same ones that
appeared the first time the computer was turned on.
7 Click Next.
The System Restore screen appears and the computer restarts.
8 After the computer restarts, click OK.
Good Luck
