Ok first you disconnect the power supply from motherboard then measure the output voltage if it is ok then there is two wires green and black at o/p of power supply short green and black and see fan is rotating or not if rotating then power supply is ok if not then open the power supply check ac voltage in the pcb if present then check dc voltage after bridge rectifier and ckeck part by part
First, If you know how to use a meter proceed. If not use caution when checking around the input as most run 400VDC Bulk at the large Cap and switchers. Check the output area on board for a -12V label. Trace it back to either an LM7912 (TO220 or TO92) they are usually in_Gnd_out. Trace from In side to the rectifier. Check for short I find a lot of these are shorted. If it checks OK then ohm out the rest of the output Rectifiers to see if any are shorted. If they check Ok come back on line and we will move on to next area.
