What does INK ABSORBER is FULL mean?What does INK ABSORBER is FULL mean?
AnonymousMar 25, 2014
ink absorber fullink absorber full
AnonymousMar 27, 2014
cannot print ink absorber fullcannot print ink absorber full
AnonymousMar 28, 2014
it will not let me print the ink absorber is full how does it need to be cleanedit will not let me print the ink absorber is full how does it need to be cleaned
You can't post conmments that contain an email address.
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
This is great for resetting the counter - and will get your printer working, BUT make an effort to clean the ink absorber pads one sponge left and two pads right. Instructions are before this in this topic. The ones on the right I accessed by pulling the plug when print heads were pausing at left side.This is great for resetting the counter - and will get your printer working, BUT make an effort to clean the ink absorber pads one sponge left and two pads right. Instructions are before this in this topic. The ones on the right I accessed by pulling the plug when print heads were pausing at left side.
I am unfamiliar with your model and the proper way to proceed, however when taking my own dead printer apart I discovered the "waste ink tank" was nothing more than a large sponge wedged into the bottom of the printer case with some hoses aimed at it. I immagine you could just buy a replacement sponge, although I'm undertain what sensor detects how full it is and if anything else must alo be done to reset it to an "ok" status.
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible. Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error) Solution: Press the <RESUME/CANCEL> button to clear the error (1700) Waste ink absorber error 1700 The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
This applies to Canon printers but since you did not specify the printer name and model here is the information I have courtesy of Canon's Support Website.
Don
The waste ink absorber is getting full. Press the OK button to clear the error. Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
ink absorber full
