Unfortunately that means either your windows installation is corrupt and needs to be reinstalled or the hard drive has failed and needs to be replaced. If you do not have a windows xp disc you will need a technician to do this as you will not be able to without the disc. If you do have a disc however follow these steps.
First insert the windows XP disc into the drive
Then when the machine says press any key to boot from CD press enter
Wait for the windows setup to load completely
Then highlight the windows XP partition it should be labeled windows XP
Then hit R on the keyboard
This will start a repair installation of windows
If the windows disc cannot find the hard drive or the repair does not completely unfortunately it means that the hard drive has failed and needs to be replaced.
do you mean your windows xp boot CD doesnt run?
