Toshiba Satellite R10-S802TD Tablet PC Logo
Posted on Feb 22, 2010
The combination fn+f8(the wi fi button ) is not working
Yestherday i bought a lap top toshiba l500-1ev .As soon as i install the operating system (win 7 64bit) i noticed that the led indicating swiching of the Wi Fi is on(in orange light) .This orange light is not responding to the combination fn +f8 it is always lighting.I also tried to switch off the Wi Fi from the mobility center : the connections are off but the light is still the same . i really need some proffessional advise . Thank you for Your attention
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
751
Points
Nothing you can do about it ... if you dont use the wireless you can disable-it from bios and the light willl shut down....
i have the same laptop ..and except the battery that goes fast it's a reliable laptop
PS you would better use w7-x86/32 bit and it will performe better
2answers
My toshiba tablet wont connect to my wi-fi please help
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
1helpful
Acer tablet
An authentication error is an incorrect password being entered. Make sure you are typing it in correctly. Remember, passwords are case sensitive. Please check with your internet provider if you are unsure of your Wi-Fi password.
How to turn on wireless
Check the top row F# key for wi-fi (look like bars or antenna.
Turn on laptop and wait until fully OS boot.
Hold function key (FN) on on bottom left and touch the wi-fi key once.
My ipod is locked
if you put it into i tunes an a lap top or desk top you can reset but it will be completely wiped
What do I do to my lap top or kindle to receive emails
There is no specific email client on the Kindle so you can only receive your emails via the experimental web browser and using a web mail service to access your mail.
When I go to use wi-fi, it keeps saying wi-fi is disabled. Yet, other laptops in the house work off the wi-fi
Do not expose the <a href="http://www.laptopsbatterysupplier.com/4200mah-replacement-laptop-battery-for-a1280-p-2055.html?cPath=9_2163">apple A1280 battery</a> to high heat or freezing temperatures. Do not leave your <a href="http://www.laptopsbatterysupplier.com/4600mah-replacement-laptop-battery-for-a1281-p-2061.html?cPath=9_2202">apple A1281 battery</a>in your car in the summer. Hot <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps8-c-32_2062.html">Sony BPS8 battery</a> discharge very quickly, and cold ones can't create as much power. 6. Fully charge new <a href=" http://www.laptopsbatterysupplier.com/sony-laptop-battery-vgpbps9-c-32_2063.html">Sony BPS9 battery</a> packs before use. New pack needs to be fully charged and discharged (cycled) a few times before it can condition to full capacity. 7. For laptops that work as Desktop Replacement, the <a href="http://www.laptopsbatterysupplier.com/toshiba-laptop-battery-pa3534u1bas-c-447_1843.html">Toshiba PA3534U-1BAS battery</a> should be re -installed every 3-4 weeks and allowed to fully discharge. 8. Leaving the <a href=" http://www.laptopsbatterysupplier.com/4400mah-replacement-laptop-battery-for-gateway-nv52-p-1904.html?cPath=35_2094">Gateway Nv52 battery</a> in a laptop while using an electrical outlet for long periods of time will keep the battery in a constant state of charging up and that will reduce the life cycle of the battery.
Toshiba Satellite m35x-s329 notebook, wireless antena
Do you have a wireless card?
If not you need to get one for it to work!!!
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
