Yamaha xt 125r wont start u, theres gas, theres compression and there's a spark but it wont work
Hello, check and see if plug is firing a blue color, if not you may need a stator-pickup coil, i have a 2000 warrior, it is firing, orange and white color, stator neede to be replaced, pickup coil was going out, also check ign coil, these have a problem with getting weak after a while. most likely it is your stator pickup coil, no blue fire from plug, no running the motor. my stator pickup coil was going out. no blue fire from plug, i was told by a yamaha mechanic, no blue fire from plug it will not run, has to be blue, not orange or white looking fire.make sure carb is clean and all jets inside are clean, and air passage ways
