press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET.
I've been trying to set the time
I've been trying to set the time but can't do it
i have a childrens watch (dont laugh) its an umbro watch with alarm and everything..50 metres resist....and watever...
but i want to know what the circle thing is for it has a black dot in middle and theres another thing theres a graph below it it has a caption that says `s m t w t f s' it means sunday monday tue....and everything but above that is a black sqaure that is on the letter w what is that graph-like thing is and how does it work
yes, but how do I activate/deactivate the alarm?
I can set the alarm to any time I like, but I can't seem to switch it off permenantly. Normally digital watches have a little lit up icon/symbol to show when the alarm is activated (maybe a dot or a small alarm bell symbol). I can usually tell when the alarm is activated because this symbol shows up, and when it's deactivated the same symbol dissapears.
change time format
change time format
RESETT THE TIME
