Gemini XL-500 Turntable Logo
Anonymous Posted on Feb 29, 2008
Got a gemini xl500 turntable - sound output problem
Is it possible to connect it to my computer speakers? I've got creative surround sound speakers...
If it is poss what cable should I buy?!
Cheers
Hannah :)
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
315
Points
OK found the solution - need to connect to preamp before my comp.
1helpful
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
3helpful
How do i connect my Creative T6160 speakers to my laptop.
Your speakers are 5.1, but your laptop has 2.0 audio output, which means that it is a simple stereo (left and right channel output). You will need to connect a USB sound card (such as the Creative X-Fi Surround 5.1) with 5.1 channel connectivity in order to connect your speakers.
Hope this helps.
Creative 5.1 A500 connected to Philips DVD Model DVP 3146x/94 with RF cable but iam getting sound from front 2speakers only. please help to get the sound from 5speakers with the connecting map.
1. Launched your Creative SoundBlaster Live program 2. In the main deck of the Surround Mixer, click the speaker button 3. In the speaker view, click the speaker selection button to select the 5.1 speaker mode if it is not selected
4. Reboot your computer
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Have linked it up to my normal surround hi fi system but no sound. No sound either when connected to my pc.
You asked this question in the TTUSB category. Do you have that turntable and how are you connecting it to the surround sound?
The turntable has a USB port and corresponding EZ Vinyl software that lets you monitor the output of the turntable. Then you can connect the computer sound card to speakers to hear what is playing.
Carl
Reply...
Creative Sound Blaster X-Fi Surround 5.1 will be the best option as creative soundcard worls great with creative speakers....
One Connector not working on Durabrand SA-SP9 Surround Sound
you have to test electrical out put, maybe loose wire inside or blown component
2answers
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
CONNECTING SPEAKERS
you must have surround sound card/output from your computer to connect surround soud speakers.
if so, then put the right jack to right pin.
1helpful
Sound problem
I have a creative SoundBlaster LIVE! 24 Bit External Sound Card and this annoyed me for weeks.
depending on your surround sound reciever depends on the solution.
i have an Acoustic Solutions surround sound system with coxial and optical inputs, aswell as stereo red & white jack inputs.
not knowing the method or connection your using makes it difficult to give you a single solution so i'll list a few.
The soundblaster software shoudl include the Creative Audio console with all sorts of effects, one is CMSS (CMSS-3D) Stereo widening which is still stereo but gives a surround sound effect.. but i'm guessing you payed for 5.1 and you want 5.1 onto the next part
5.1 surround sound can only be produced when the actuall audio your playing contains 5 channels of audio, for example you cant play a stereo song in 5.1 surround sound without some sort of hardware or software sound manipulation. Luckily my surround sound system has Pro Logic II built in and some other effects which convert a 2.1 signal to a 5.1 signal and it works brilliantly. I'm not sure of a software alternative.
setup for your soundcard will be different under XP and Vista also, but there should be a properties option for your sound device where you can select your speaker setup such as headphones, built in speakers, 2.1 speakers, 5.1 speakers, 7.1 speakers and you should be able to manage this from the creative software.
If using Coxial / Optical or SPDIF under vista you MUST set the playback device as SPDIF, at least you have to with my sound card and drivers and seems to be a limitation of the actual sound card drivers for vista.
Personally i was looking forward to hearing the windows login melody in 5.1 surround sound too, but this doesnt happen.
Infact i find that almost all programs bar a few will not play Dolby Digital or DTS 5.1 surround sound via any or my output options hence the next solution..
if you have the 5.1 sound but winamp simply just plays it in stereo try the following.
You need to use DirectSound Output:
Preferences (Ctrl-P) > Plug-ins > Output > Select "DirectSound Output"
That should work in most cases, but if not, then:
Checkmark: "Allow hardware acceleration" in DirectSound Output config,
and make sure your sound card/chip is selected as Output Device.
Note that any changes will take effect only after playback is restarted.
In some cases, a Winamp restart is required.
If that doesn't work make sure you have the latest version of DirectX
(v8.x or higher is required)
Winamp 5.25/5.3 and higher:
For actual multi-channel files (ie. aac/wav/ac3/ogg/wma files encoded in 5.1ch surround, as opposed to standard 2-channel stereo mp3's), you need to checkmark "Allow surround sound" in 'Winamp > Prefs > Playback' for the music to play in its original 5.1 channel format (Note that this setting is checkmarked by default).
Windows Vista:
In addition to the above instructions, Vista users will also need to go to:
Control Panel > Sound > Playback tab > Speakers > Configure:
Select: 5.1/7.1 Surround.
Then:
Control Panel > Sound > Playback tab > Speakers > Properties > Enhancements tab
and checkmark "Speaker Fill"
Hope this helps
Anthony Kinson
Top Gemini Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Gemini Audio Player and Recorder Expert? Answer questions, earn points and help others
