Hi, I have a Panasonc Lumix DMC TZ2 digital camera. When i turn it on the screen is just black, and when I take a photo the picture is just black. However, there appears to be nothing wrong with the LCD screen as I can view previously taken photos fine. Can you help, Thanks Donna
i ve got the same problem with tz2 my screen is black, cant take pics, help me plsi ve got the same problem with tz2 my screen is black, cant take pics, help me pls
hello, I have the same problem. the problem is in the CCD. repair is very expensive. I have tried repairing, checking connections, without success.I have the technical manual but I have not been repaired. Can anyone provide more information, please. Thank you very much.hello,
You can't post conmments that contain an email address.
Not sure it is on every picture you take, but digital cameras doe have problems with bright lights in a dark environment. From such a light bright lines can go horizontal. If in normal light, your camera does not have the problem, I guess you now have an explanation.
This is caused by a bad or loose ribbon connector to the LCD screen...the only way to fix that is to take the camera apart and reconnect the ribbon connector.
You also can do a search for camera repair and send it away, but often the costs are more then the camera is worth...
If you do try to repair the camera be advised that there are dangerous voltages inside even cameras...be careful!!
You have to change the lens assembly, if you are lucky enough to buy the parts cheap on ebay. If it is contact resistance problem, you can just pat it in any direction to see if the image is improved.
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Click and open MyComputer window, connect and turn on your camera, wait for a while, if you can one more icon(maybe a folder, maybe a camera) show up, click and open it. You’ll find your pictures there. Just select, copy/paste or drag the pictures to wherever you want.
See more details here How to download pictures without camera driver
Donna, did you find a solution to this? I have got the same problem...
hello,
