Cellular Innovations HFBLU-CX1 Wireless Headset Logo
Posted on Feb 22, 2010
How do i get my bluetooth, model: HFBLU-10k to be in the pairing mode?
2 Related Answers
Anonymous
  • Posted on Jun 02, 2009
SOURCE: i just bought the hfblu-10k
I was given this bluetooth after a buddy of mine could'nt figure it out. I figured out how to sync it by following that longer than 5 secs. idea that's posted here. I did'nt have a manual so I just put in "0000" and it worked! So try that...Good Luck. Thanx4Hating
Anonymous
  • 32 Answers
  • Posted on Jun 30, 2009
SOURCE: my model # hfblu-s1 bluetooth needs a passkey to install
0000 or 1234 are usually the default codes for all bluetooth devices
1helpful
I put my HFBLU-LT200 bluetooth headset on charger and both blue and red light have turned on permanently. Bluetooth has stopped working
That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
2helpful
I have a blue tooth model HF BLU-10K by Motorola and have lost the book to program it into my new phone. Any ideas?
1ST IT IS NOT A MOTOROLA PIECE. IF IT IS A MOTOROLA PIECE I APLOGIZE BUT I MAKE THE HFBLU-10K. IF ITS A CELLULAR INNOVATIONS HFBLU-10K YOU CAN EMAIL ME AT [email protected] AND I WILL SEND YOU A COPY OF THE MANUAL
Cannot get my 'Sanyo SCP-2700' to connect to my bluetooth Headset
go to your phone and turn on your blue tooth.that might be the problem.
4helpful
I have misplaced the information on how to work my bluetooth headset (HFBLU-1K) could you send me a new one Thanks
Hi
These instructions should work for pairing your bluetooth device
1. First turn OFF the Bluetooth Headset
2. Place the Headset within a distance of 1 Foot of your phone.
3. Hold down the power key for about 8 seconds until indicator light blinks and starts to alternate between red and blue. This shows it is in pairing mode
4. Set your phone to search for a bluetooth device.
5. Select HFBLU-1K in the bluetooth device list and if required enter the password 1234
Hope this helps. Do let me know how you get on and remember to rate my answer. Thanks.
Can the hfblu-1k be reset?
you do not have to reset it to pair it with another device. you simply have to put the earpiece into pairing mode again as you did with the first phone and follow the same steps you used initially to pair it to the device that broke.
6helpful
I have a cellular innovations bluetooth headset model number HFBLU-10K and I am trying to sync it with my iphone and I am having trouble. Is it compatible with the iphone? Lynda
yes, this item is definately compatible to the iphone. try this:
1) turn bluetooth unit completly off
2) make sure bluetooth function in your phone is turned on
3) from the off position hold down the (mfb) or power button as if you were turning on the unit
4) you will see a blue light indicating the btooth is powering on DO NOT LET GO OF BUTTON
5) after blue light you will see red and blue light start to flash together..when you have achieved this state you can let go of the button
6) go to your phones btooth menu and go to where it says add a device or search for devices(terminology different in every phone)
7) your phone should search and find it, it will come up as hfblu-10k.. after it finds it just follow the prompts your phone gives to complete the set-up. FYI password is "0000"
33helpful
4answers
I just bought the hfblu-10k bluetooth headset today. i followed instructions to sync it with my lg vx5300 verizon phone and my phone was unable to detect the headset. i also tried syncing it with my acer...
25helpful
3answers
Need a users guide (instructions)
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
22helpful
4answers
BT pairing code
Top Cellular Innovations Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
