You will need to replace both convergence ICs and also possibly the associated low ohm resistors, since the 3 blinks is indicating that the convergence has failed. The PT47WX52 convergence repair kit is available from www.tvrepairworld.com which has the two ICs , heat sink paste, low ohm resistors and the CD with repair instructions.
Hi, 3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem. Click Part Store to see an image of required chip and price info. Local tv tech is recommended if you have no experience of working in tv circuit boards. Thanks.
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code
refers to an power set up problem,see incoming voltage with an
multimeter.......
WHEN POWER IS FIRST TURNED ON I HAVE A SOLID RED LIGHT BUT NO PICTURE. THEN YOU HEAR THE TV CLICK OFF. THEN RED LIGHT STARTS TO BLINK IN SET OF (3) TIMES.
