Okay so this may not help you now, but I just got a hand me down D780.
After much frustration and research here's the solution that I was able
to work with. It isn't perfect; but it's something....
So here
are the steps for network shared installation; assuming your D780 is
installed on an old xp desktop and you're using a Win-7 laptop. If
you're using the printer directly on your Win-7 machine, just use the
local printer installation after the XP mode has been installed.
1)
You'll have to install WinXP mode on Win-7 using the steps listed on
this link. If you have a genuine Win-7 copy installed, this download
and installation is free, courtesy Microsoft.
http://windows.microsoft.com/en-us/windows7/products/features/windows-xp-mode
2)
After installation, you'll have to change network settings for your
virtual pc. This step is necessary if you want to be on the same home
network and want to see the printer! Never mind if you don't understand
this logic. Just follow the steps and you'll do just fine. To change
the network settings in vPC: click Tools; click Settings; select Network
from left; then for Adapter 1 choose the actual network adapter
connected to your router (simply put: select the wireless adapter or
wired adapter you're using to connect to your actual router or home
network. You can find that from Change Adapter Settings in Network and
Sharing.) Click Ok.
3) Now add the printer as local or networked
following your usual XP steps. You should be able to see the printer.
If not, open a command prompt window, check your ip to make sure you're
on same network. If not, or if you don't know how to do that, just
type in ipconfig /release enter and then ipconfig /renew enter. Try to
connect to the shared printer by pinging the ip of the host computer.
If the ping works, you should be able to see the printer then.
Connect printer and use in XP mode. Not the best solution, I
know. But it's free and at least lets you print from your laptop,
given the circumstances.
So here
1)
http://windows.microsoft.com/en-us/windo...
2)
Sharing.) Click Ok.
SOURCE: Vista 32-bit driver for MF3110
Go to Canon MF3110 Support
If the Drivers & Downloads tab is not selected, click on it.
From the drop down menu, select your Operating System (Vista).
A link will appear in red in the Drivers block that appears. Click on the link to download it. The best thing to do is to select Save when the download window opens and save it to your Desktop. You can then begin the installation once the download is complete.
The Setup Guide is also on that same download page if you need it. Just remember when it says to insert the CD, just double-click the file on the desktop.
Thanks for using Fixya.
Testimonial: "Excellent advice thanks"
SOURCE: driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
SOURCE: Canon LBP 2900 drivers 64 bit?
64 BIT driver for canon 2900 now available from canon uk website
SOURCE: printer canon pixma IP1000 does not work on windows 7 64-bit
here are the windows 7 64 bt drivers
http://software.canon-europe.com/software/0035868_0010104.asp?model=
click
aomwin110ea24.exe
4070.33 Kb.
under the software label to the buttom if the page
SOURCE: canon mf3240 won't print on my windows 7 64 bit
Try follow my instructions here --
http://andrewtheart.blogspot.com/2010/06/installing-canon-mf3240-on-windows-7-64.html
