Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon ir 3530
I want to now some error codes canon ir 3570
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on May 04, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673735
Points
2880
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Robert cruse
Level 3:
Master:
  • Canon Master 336 Answers
  • Posted on Nov 25, 2022
Robert cruse
Canon Master
Level 3:
Master:
Answers
336
Questions
22
Helped
299650
Points
1037
Canon printer shows error codes due to some mechanical or technical issue. Find here more canon printer error codes and their solutions.
will joe
Level 2:
Sergeant:
  • Canon Expert 321 Answers
  • Posted on Nov 10, 2022
will joe
Canon Expert
Level 2:
Sergeant:
Answers
321
Questions
0
Helped
136014
Points
930
Reset the Canon printer
Press 'Setup'.
Go to 'Device settings' and press 'OK'.
Go to 'Reset' and press 'OK'.
Go to 'Reset everything' and press 'OK'.
Select 'Yes'.
Press 'OK'. Your printer has been reset.
Regards,
Will
1helpful
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Ir 3530
please cleen your scanner home position sencor
1helpful
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
2helpful
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
104helpful
13answers
Cannon ir 3530 all error code and solution
Code Error name/description
4helpful
Message E00024-0001 sur Canon IR 3530
you have paper jam blow out with air in can real good.
4helpful
2answers
old marine
old marine
ZJ Limited
ZJ Limited
