Baumatic B187 Electric Single Oven Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Baumatic B180W-B oven does not heat up. The
My Baumatic B180W-B oven does not heat up. The grill still works and the fan, the light, the clock etc.?
Barry Coates
Level 3:
  • Baumatic Master 3,463 Answers
  • Posted on Feb 21, 2010
Barry Coates
Baumatic Master
Level 3:
Answers
3463
Questions
Helped
1406874
Points
12766
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Baumatic B144SS Oven Not Heating Up.
You can test elements with a ohm meter. Cleaning temps get extremely high and will often damage an ovens electronics
1helpful
7helpful
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
2answers
Baumatic oven not heating up
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
[email protected] hope this helps
Jan 13, 2008 • Ovens
1helpful
2answers
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
