Uniden BC248CLT Base Scanner Logo
Posted on Feb 28, 2008
Radio scanner not receiving
My realistic pro 2025 scans but boes not receive any signal,not even the weather. I have a radio shack pro-49 that receives and both have the same fregs.
  • JimDgrz Apr 08, 2008
    I have a PRO-30 with the same problem. The radio will scan, but does not receive, including NOAA weather. While I'm not good at electronics, I think I'll take it apart and start by looking my antenna wire. After this, I'm not sure what to look for.
    Anyone have some troubleshooting ideas???
jon d
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Feb 01, 2014
jon d
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
18520
Points
73
I ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
  • jon d
    jon d Jun 24, 2014
    sorry folks grab the tissues cause thats the end of a long relationship.... shel be missed, at least until i got the 2006 and a new partnership blossums
EDACS
Level 1:
Scholar:
  • Contributor 66 Answers
  • Posted on Jul 08, 2008
EDACS
Contributor
Level 1:
Scholar:
Answers
66
Questions
0
Helped
24696
Points
90
The Realistic Pro-2025 relies on a quartz lock-loop signal synthesizer to receive signals, the synthesizer might of gone bad, chalk it up to old age. The Realistic PRO (Progressive Receiving Occilator) models are not around anymore, they went obsolete years ago. It's nice that you have one, they are worth some money on eBay. However I'm afraid it will cost you more money to fix the synthesizer than the radio is actually worth. It would be best to use your Radio Shack PRO-49. Realistic is a division of Radio Shack founded by Tandy Corp, basically you've been using a Radio Shack scanner the whole time. So if you have any complaints, take it up with them, you won't find Realistic anymore.
Hope this helps!
Owners manuel for Radio Shack Pro-2039
Nope... seems that since Radio Shack folded up it's tents almost all of the old links have dried up! And GEE, I had one of these scanners but have no idea where it is now?
A FEW of the exceptions follow...
PROGRAMMING
This Link is for the Pro-2021 BUT your PRO-2039 programming will be much the same!
Radio Shack Realistic Pro 2021 Scanner Programming and Overview
This link may help you too but it's a much more advanced scanner!
RadioShack Pro 2050 Scanner Programming Tutorial Police Scanner
PRO-2039 SPECIFICATIONS RigPix Database RadioShack Realistic Pro 2039 20 7462
GENERAL Type:VHF/UHF receiver/scanner Frequency range:66-88 / 108-174 / 380-512 / 806-960 MHz (Europe) Tuning steps: Mode:AM/FM Channels/memory management:200 regular in 10 banks @ 25 ch/sec
10 monitor Power supply:Mains Current drain/power consumption:Max 13 W @ 230 VAC Antenna impedance/connector:50-75 ohms / ? or built-in telescopic whip Dimensions (W*H*D):190*80*180 mm (7.5*3.12*7.12") Weight:1 Kg (2.2 lbs) Other features: RECEIVER SECTION Receiver system:Double conversion superheterodyne
1st IF: 10.7 MHz
2nd IF: 455 KHz Sensitivity: Selectivity: Image rejection: AF output power/speaker:1 W at ?% distortion / 8 ohms External speaker connector: MISCELLANEOUS Manufactured:China, 199x-199x (Discontinued)
For "PURE AUDIO" there is a MODIFICATION/Link:
http://schreiber.pl/mods.dk/mods.php3-radio=radio_shack&model=pro-2039&selectid=1855.htm
ANTHONY
Realistic uhf/vhf model 20-400 pro 58 ten channel. Where can I get an owner's manual?
Good Evening Pam
Radio shack has a listing of Scanner resources here:
Radio Shack Realistic Scanner Manuals The materials for the Pro 58 are here
http://support.radioshack.com/support_electronics/8570.htm and gives access to specs, parts list, features, and a guide to scanning. It's very mid-20th century in appearance, including using type-writer style fonts.
Hoping this helps!
D
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
2answers
My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
www.RadioReference.com
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
2helpful
My pro-82 scanner scans threw all channels but will not pick up any frequencies?
To verify that the scanner is working properly, program one or more of the weather frequencies(162.4, 162.425, 162.45, 162,475, 162.5, 162.525, 162.55, 161.65, 161.775, 163.275) into memory and then scan. NOTE: Not all frequencies are in use in all areas, so you may need to try several. If you receive the weather broadcasts, then you may need to adjust the squelch setting on your scanner to receive local signals. You also need to verify that the frequencies programmed into the scanner are valid, active frequencies in your area. For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
If the scanner fails to receive the weather broadcasts, you need to check the antenna connections inside the unit and/or have the scanner checked/repaired by a qualified technician.
Bill B
Hi, i have a PRO 2025 Realistic Scanner, it is a
eBay has numerous antennas that will work for you, mostly in the $20 -$30 range. Here's a link to one of the listings:
http://cgi.ebay.com/NEW-MINI-MOBILE-SCANNER-ANTENNA-MAGNET-MAG-MOUNT-KIT-/220596857646?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335c98eb2e
You can also pick up a compatible antenna at any Radio Shack store.
Bill B
Well you will need to get it at Radio Shack,they just plug right in the back of it . nice ...hope this helps..
CAN MY RADIO SHACK PRO 97 HAND HELD SCANNER BE MADE TO RECEIVE DIGITAL SIGNALS?
The pro 97 is designed to receive analog signals. You will need to spring for a digital receiver if you want to go digital.
2answers
Pro-82 scanner
go to cityfreq.com and see if the frequencies in your area have changed. you might even need a new anteanna radio shack should have a really good one for 20 buck. a little longer than the original but good
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
