Watches Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to resize a watch band for my mother. It is a stretch band with links
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1290931
Points
7081
I suggest you take it to a watch shop (decide how much shorter you need it before you go - or take mother and watch to the shop).
It is very quickly done when you know what you are doing and have the tools!
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
tip
How to resize a (Casio) watch band
Because there are a lot of questions about resizing watch bands, I thought I'd add a tip how to do it. Roughly two types of links are used with Casio watches, so I've added two how-to video's:
on Mar 26, 2015 • Casio Watches
Montres Carlo. How can I shorten the band?
WATCH BAND ADJUSTMENT / RESIZE - HOW TO - YouTube
? 5:51
https://www.youtube.com/watch?v=N42D4lwD5Ok
Dec 25, 2013 - Uploaded by Phil Crockett
This video shows how to adjust the size of a watch band by removing extra links. This video is "to ... +Jay Carlo Aguilar Glad my video helped you out! Makes my .... Can't wait to challenge my smartass Grandkids to figure it out.
How to Resize / Adjust a Watch Band - YouTube
? 6:39
https://www.youtube.com/watch?v=o3NfebIjLlU
Sep 15, 2012 - Uploaded by Nils Rasmusson
Learn how to adjust a metal / silver / gold watch band or how to resize a ... A couple of pins on my watch broke and I bet I caneasily fix this for ...
Jan 19, 2016 • Watches
Link removal from bracelet?
    1. Use the steps below to remove your band. You must separate the Link Bracelet into two pieces before removing the band from your Apple Watch. While removing the band, don't force the band or twist it. Use the steps below to avoid damaging the band or clasp.Jun 19, 2015
      Remove the Link Bracelet on your Apple Watch - Apple ...
      https://support.apple.com/en-us/HT204831 Apple Inc.
    Feedback
  1. How to resize or remove links from your Magnetic Bracelet ...
Jan 01, 2016 • Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
3helpful
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 • Watches
1helpful
Resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Jan 10, 2010 • Watches
Watch band resizing
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
* I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
12helpful
3answers
How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Feb 13, 2008 • Watches
Wrist Band Resizing
I did find a solution. I used a push pin tack to push the pins out. Not easy but it did work.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
