Question about Braun MP-80 240 Watts Juicer
Anyone have the assembly guid? i fixed the switch
Anyone have the assembly guid? i fixed the switch but do not know where 3 springs go as they fell out and I was not paying attention.
    New Friend:
Hello did you find out were the springs go i have the same problem
Posted on Aug 01, 2010
  • dalewilson1 Nov 01, 2010
    I took it apart but cannot figure out where the big spring goes, the white little 'lego' piece or how this all ties in to the switch.
6ya staff
SOURCE:
Russell Hobbs Juice Extractor Won't Start
if it is intermediate workings there is a micro switch that is a must so it wont turn on when your fingers are in it might have some junk in it clean your machine. look if the micro switch fell inside machine ?
May 12, 2014 | Juicelady JL500 Juice Extractor
Tribest green star 1000 toggle switch assembly
888.254.7336 or service@tribest.com
there are 3 or 4 service centers in the usa that can help with this repair or just sending you the part if you feel you could do the repair.
Dec 17, 2012 | Tribest Green Power GS-3000 Juicer
I took my juicer apart and now I am trying to re assemble it but I don't know where the springs go. Please help
they attach to each side of the metal bar. i threw the springs away because i couldn't figure out where they went, and now the unit shakes like crazy :) but i read up on it and found out the springs go on each side of the bar i think. 50 bucks will replace the bottom part of the machine (base and motor) https://www.unitycart.com/pjss/parts/parts_classic.asp
Jul 26, 2011 | Jack Lalanne Power Juicer 250 Watts
Don't know how to set up Jack lalanne power juicer
First, check that the switch is in the on position. Then, check that all parts are assembled properly. The unit has a built-in safety device that will not let the motor turn on if not assembled properly. The Power Juicer also has a built-in Thermal Cut Off Safety Switch. If the machine was running, then shut down due to accidental overheating, then there is a 10 minute cooling time before the machine will restart. This helps to protect the motor from seizing. Click on the link below and select your juicer model to view the instructions and operating manual
http://www.powerjuicer.com/customer-manuals.html
Apr 15, 2010 | Juicers
I have a Jack la lane power juicer and the power switch did not work. So I dis-assembled the motor and power switch and found 2 springs. Now I want to assemble it back but did not know where these 2...
The stainles bar has 2 springs on each end. Maybe this is the springs that you have. It is a power safety switch wherein there is no power if the bar is not seated in the right place.
Jul 06, 2009 | Jack Lalanne Power Juicer 250 Watts
Replacement part needed
TRY 800 424 6783. PERSONALLY USING
A BREVILLE IS LIKE HANDLING A LOADED
WEAPON. MIGHT WANT TO CK OUT THE
OMEGA 4000.
May 06, 2009 | Juicers
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Nov 09, 2006 | Champion G5-PG-710 650 Watts Juicer
Braun MP-80 240 Watts Juicer Logo
247 people viewed this question
Top Braun Juicers Experts
Jay Plesset
Tom Chichester
adrian Brody
adrian Brody
Are you a Braun Juicer Expert? Answer questions, earn points and help others
