You can try to remove the spray nozzle if it unscrews and soak it in vinegar or CLR (Calcium,Lime,Rust available at stores) solution. Yes or use vinegar water mix 1/4 c vinegar 2 c water, or again there are products that are made for iron cleanout but vinegar is the least chemical based and cheaper. Fill the sprayer with the solution, and the steamer also. Operate the iron on the highest steam setting and iron on a folded towel to clean it out. You may have to scrape out the scale build up from the sprayer if it wont clear with the solution.
Clean an iron:
Service the steam and spray mechanism:
