How do i make my logitech cordless skype phone connect
I have a logitech cordless skype phone and the handset reads disconnected.. how do i connect? skpe on my computer reads logitech in appropriate device section.
Re: how do i make my logitech cordless skype phone...
Unfortunatly since the skype version 4 the Logitech Skype IP Phone is not longer supported.
You will not be able to sync the contact from skype to phone, and might not be able to connect as well.
Thanks and have a nice day J -
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
this dosnt work this way,
go to the logitech site, look fore the right set, disconnect the usb connector from de pc, then download/install the right software en untill you asked fore plug in the usb connector then plug in, it will working, unless you have installed msn under windows vista, this is not working togehter.
make sue your on the latest software and there is no interference from other 2.4 ghz devices. also place receiver at a distance from the pc it self the emi can disconnect the phone.
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Thanks,
CompGoddess
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
