Computers & Internet Logo
Posted on Feb 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Could not install windows xp service pack2
I HAVE A COMPAQ PRESARIO V3604TU LAPTOP. I AM TRING TO INSTALL WINDOWS XP SERVICE PACK2. BUT WHEN EVER I TRIED THE SETTINGS INFORM ME "THERE IS NO HARD DISK DRIVE FOUND". BUT WHEN I INSTALLED VISTA IT INSTALLED EASILY.HOW CAN I INSTALL WINDOWS SERVICE PACK2?
  • nanai Mar 17, 2008
    first u need to partition the hard disk , after install windows xp ok
    any doubt 9985244055
  • horizonsahib Apr 13, 2008
    I have the same problem ?
Anonymous
Level 2:
Sergeant:
  • Expert 406 Answers
  • Posted on Feb 28, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
406
Questions
Helped
162272
Points
868
You need sata driver for your hdd. to install Xp you need usb floppy as well. (i.e.) for drivers for sata during xp installation.
2helpful
2answers
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Sound driver installation failed
Maybe the sound driver is not designed for you OS or hardware. You can check the compatibility before installing.
Can't install XP service pack2 on my AcerPower f6 computer.
Did this machine have Vista intalled originally? I checked Acers' support page for your model and I didn't see a xp sata driver.
1helpful
3answers
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
4helpful
2answers
I Need Audio driver for Compaq c 700
i need audio drivers compaq presario C700 for windows xp service pack2
2helpful
2answers
Audio driver for C740TU,compatibale with win XP sp2
For a Compaq Presario C740TU Notebook PC running Windows XP, audio drivers would be for Conexant High-Definition Audio. Importantly, SoftPaq Number SP31994, "Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio," (or later) must be installed on the notebook before installing SP32823.
  • sp31994.exe 1/1 (6.12M) (ftp://ftp.hp.com/pub/softpaq/sp31501-32000/sp31994.exe)
  • sp32823.exe 1/1 (6.12M) (ftp://ftp.hp.com/pub/softpaq/sp32501-33000/sp32823.exe)
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
How can i install XP sevice pack2
1) Service Pack 2 is a service pack, not an operating system - you first have to install XP itself, which you'll have to buy.
2) It's entirely possible that there are no XP drivers available for one or more components of your laptop, so XP won't install on it. (Linux probably will.)
Grand Canyon Tech
Grand Canyon Tech
