Gympac 1600 manual
Device error
An internal error occurred in the device.
Press (Select) to resume the job.
Door open
The printer door is open.
The door must be closed before printing can continue.
Engine comm. error
The device experienced an internal communication error.
This is a warning message only. Job output might be affected.
Invalid driver
You are using the incorrect printer driver.
Reselect the printer driver appropriate for your device.
Invalid entry
Invalid data or response.
Correct the entry.
Jam in Cartridge area
A paper jam has occurred in the print path.
Open the door and clear the jam. Then press the (Select) button on the control panel
Jam in Output bin
A paper jam has occurred in the output area.
Clear the jam, and then press the (Select) button on the control panel.
Jam in print paper path.
Open the door and clear the jam. Then press the (Select) button on the control panel.
Jam in tray 2
A paper jam has occurred in Tray 2.
Jam in tray 3
A paper jam has occurred in Tray 3.
Load paper
The HP Color LaserJet 1600 printer is out of paper.
Please load specified paper type into the tray indicated.
Load Tray X [TYPE] [SIZE]
The printer is processing job, but the tray indicated is empty.
Please load specified paper type and size into the tray indicated.
Manual feed
The printer is waiting for paper in the tray indicated
Load the paper as indicated.
Memory is low
The device memory has been almost completely filled.
Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages.
Misprint
The printed pages have been incorrectly placed on the paper.
To continue, press the (Select) button on the control panel.
espon xp 400 printer is giving me hell. First off it wont feed at all it doesnt even attempt but the rollers spin. Then I get a warning message saying that theres a paper jam but the printer didnt even feed the paper throught
