Question about Sharp KB-6015KS Stainless Steel 1000 Watts Microwave Oven
Sharp KB-6015K drawer won't open - Sharp KB-6015KS Stainless Steel 1000 Watts Microwave Oven
  • 3 more comments
  • Anonymous Feb 19, 2010
    Model #KB-6015k sharp microwave drawer has an automatic open and close function that will not work. the oven was in DEMO mode after the power outage. I unplugged it to reboot and plugged it back in. the oven works now except for the auto open and close function.
    I already contacted sharpusa.com and the three providers do not service this microwave drawer. It is 5 years old so out of warranty.
  • Mario N Dec 07, 2019
    The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
    1) Push the draw all the way closed
    2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
    3) Hold the Start Button until the time reappears in the display.
    4) Repeat steps 2 & 3 three more times
    5) Unplug the Microwave for 30 minutes.
    The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Posted on Dec 07, 2019
Your microwave should have a one year warranty. Contact Sharp for their nearest authorized servicer at 1-800-BE-SHARP (1-800-237-4277) or visit them online at this link:
http://www.sharpusa.com/CustomerSupport/ContactUs/ContactUsProductSupport.aspx
Posted on Feb 19, 2010
  • 1,871 Answers
Hello :
If it opens little bit then i advice you to take a doctor syringe filled with break oil that you use in cars and inject the joints of the door with it . Don't give it big loads , just little stitches .
If it doesn't open at all , then put it in a warm or better extra warm (not hot ) place or atmosphere for about two hours until the it absorbs the temperature of the place , then grab it from the door handles and dip it in extreme cold water while holding the door handles , don't dip the door inside the cold water . Now it should open ... after it opened i advice you to do the syringe trick.
if you did the syringe trick , i advice you to let it for a long while to let the brake oil get deep inside the door joints ..
By the way you can use this syringe trick with noisy doors and windows at home ..
good luck ..
i hope that helped .. if yes , rate me well please !
Posted on Feb 20, 2010
  • 1,284 Answers
Hi, there are two ways to this problem.
If it is a simple counter to microwave oven, then you can remove the cabinet, open the door from inside of the microwave to diagnose the problem...
But if it is an over the range model, then it is more complicated and you probably have to call a qualified technician to fix it.
In any way replacement parts, most likely, have to be ordered from Sharp only....
Take care
  • Catrinka
    Catrinka Sep 17, 2014
    He's saying their drawer microwave is no longer opening/closing by itself. Not a door. Ours is now doing the same thing, resetting the power didn't do anything for it either. :(
6ya staff
SOURCE:
Microwave is sparking in rear left corner. Replaced waveguide cover, but still sparking.
Make sure is clean and your wave deflector might be deflector is defective. It s little fan looking thing that spins like a fan. To throw mwaves around the cook area..
Nov 02, 2015 | Sharp KB-6524PS 24-Inch Microwave Drawer...
Sharp KB-6524PS no power
There probably is a fuse inside but replacement depends upon your degree of comfort with disassembly while maintaining awareness of the dangerous voltages lurking inside.
Jan 14, 2014 | Sharp Insight Pro Series KB-6524PS 24""...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
Where can I buy a Sharp drawer microwave in the UK?
Hi
You can check out these links to buy Sharp Microwave in UK:
Link 1
Link 2
Hope this helps...please post back for further assistance.
Daniel
Mar 18, 2011 | Sharp Insight® KB-6002 1000 Watts...
My Sharp drawer microwave will turn on but half the time the food soes not heat up at all. I can tell there's a different sound to the unit when it's on and heating but the sound is different when it's...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 31, 2010 | Sharp Insight® KB-6002 1000 Watts...
Unit was working than just shut down, the display went dead.
hello,
the solutionhas noting to do with reset button or code
what the problem is from the element (heat provider)it is always is silver colour all it means is there is disconnection from it or it is bad.
what you need to do to fix up your oven is to unscrew it and then trace down the wire to the heater (element) but if you did not see any sign of disconnection then you will have to make a change of the element it mean bad .
thank you and thanks for using fixya.
Jun 01, 2010 | Sharp KB-6015K 1000 Watts Convection /...
Microwave has no power
Sounds like a power board malfunction. Repair technicians usually have a minimum "bench fee" probably $50 - $75 / hour but they should be able to fix it within that hour. You will also have to purchase the power board, probably around $100 so you're probably talking about $165.00 to have it repaired.
Good Luck
Oct 08, 2017 | Sharp KB-6015K 1000 Watts Convection /...
Sahrp microwave drawer doesn't automatically
It will have a one year warranty.
I would contact Sharp for their nearest authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Nov 27, 2009 | Sharp Microwave Ovens
How can I get the power to come on my Sharp microwave?
The problem may be an electrical one. Microwave ovens require a lot of power. Often, they use most of the power available to the circuit they are plugged in to. If there is not enough power in the circuit to feed the microwave and whatever else is plugged into that same circuit the fuse will blow or the circuit breaker will kick off.
Go to your electcical box, and check the breakers or the fuses. If one of the breakers has kicked, reset it by pushing it all the way off and then back on. If the fuse is blown, unscrew it and screw in a new one of the same amperage.
good luck. please rate my answer. thanks
Feb 12, 2009 | Sharp KB-6015K 1000 Watts Convection /...
Microwave Ovens Logo
886 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
