Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Anonymous Posted on Feb 19, 2010
I want to take pictures of The Northern Lights. What setting?
I know I shouldn't use flash
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Feb 19, 2010
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428896
Points
622693
Correct, you don't want the flash.
Some cameras have a fireworks mode, Unfortunately, the SD400 doesn't. As far as I can tell, the SD400 doesn't even have a landscape mode, which would have been my second choice.
I'd start by turning off the flash in Auto mode. Unfortunately, the camera is going to try to make the night sky a medium gray. You'll have to reduce the exposure using the exposure compensation feature. Review your pictures and examine the histograms to fine-tune the exposure.
My other approach would be to use the manual mode, reviewing the images and histograms.
Either way, take lots of pictures. Feel free to experiment with various exposures. Remember, there is no "magic bullet." Your sky isn't going to look the same as mine, so my settings won't necessarily do you any good.
Testimonial: "Thanks that was very good advise. Sounds though like I have the wrong camera, ha ha "
Need wiring diagram or wiring colors to install replacement switch
Contact http://www.greatnorthernpopcorn.com/ For detailed information.
But, the color scheme should be the same for each switch. If you are replacing only 1 switch, you can copy the colors from the other switchs
Funny ghost circles on image on long exposures zoom lens
Is there any way you could post one or more of these pictures so we can see it? From the verbal description alone it could be lens flare, caused by reflections from the internal surfaces of the lens. Without actually seeing it...
Memorey full delate some data first
try to delect some massages in your in box, delect some items in your muilt media like pictures you don't really need, music you don't want e.t.c because the memory is full can not save anything again execpt you delect some items you don't need.
1helpful
I am going in search of the Northern Lights tonight and the tour company say we cannot use flash photography, I have got my Lumix DMC TX3 camera with me at work but the instructions are at home - how do I...
Press Left on the four-way selector to bring up the Flash menu. Navigate down to "FORCED OFF" and press "OK" to select it.
When you're done, don't forget to turn it back on.
Christmas lights
No flash and set the shutter a little slow also use a camera stand if possible!
2answers
Panasonic
Throw out the vcr. It could be that the heads inside of it have gone bad. If this doesnt work let me know.
Northern lights
This is a defective CCD known to Canon. They will replace the defective part at no charge. Go here for details: http://www.imaging-resource.com/badccds.html
1helpful
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
