The DVD power surges when it is trying to start, the display goes dim then it opens not playing at all, the dvd dose not turn when loading unless helped.
I would really appreciate some assistance with this one,
Thanks.
SOURCE: UNLOCKING CODES
That Is The Same Code I Have It Should Work Make Sure Its All Being Entered From The Factory Remote.
SOURCE: I have a Sharp DV-RW550U VCR/DVD Recorder
check for bad capacitors (make sure its top is not bulged), check for bad step down transformer on unit. one or more of these may need to be replaced, if you are replacing faulty capacitors, make sure they are of same uF ratings, the unit will accept a +/- tolerance difference of 10%
SOURCE: I would like the region free code and how install
Hi, kindly get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__cdx
