Brother DCP-7020 All-In-One Laser Printer Logo
Anonymous Posted on Feb 19, 2010
I'm getting ghost images on multi prints to the point it is unreadable, is this the drum or fuser?
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Feb 19, 2010
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1130359
Points
8732
The only way to tell is to start a print and power off when print is still inside. If you see the ghost before the fuser it's the drum, if clean before the fuser, it's the fuser. You can also open the back door and look at the fuser roller with a light, the fuser roller should be clean but if the roller has images it's time for a fuser.
Testimonial: "thanks"
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Mar 09, 2010
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286542
Points
2705
I suspect you have people taking the blank pages that print out after a fax and feeding them back through the printer to save paper. The old paper picks up a charge when fed through the first time, pulls toner up the second like a magnet, and deposits the toner onto the toner drum. When the next sheet comes through, the image pulled from the last sheet (or the sheet before) and is transferred over the new image. Change your toner and print several pages to the printer, see if the image fades and goes away. If it does, tell people to either stop feeding the blank pages through, or to at least turn them over and put them at the bottom of the paper stack. This will give it time to dissipate the charge before feeding back through.
1helpful
Ghost image on a hp CM1415
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
Hp laser jet 3015, 7 horizontal lines, with ghost images printing/copying.
Hi:
Ghost images or repetitive image defects can be caused by one of two things. Either your toner cartridge is defective or your fuser is bad. The fuser is the component that heats up and fuses the toner to the paper. To determine which one it is do this. Start to print or copy something and shut off the printer just as the paper is going under the image drum but before it enters the fuser. If the problem you described is evident on the paper at this point then the problem is related to the drum. If the problem is not showing up on the paper at this point then the fuser is the culprit and it most likely would cost more then the unit is worth to repair.
Andrew
Ricoh aficio SP c231n prints ghosts images
sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
2answers
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
6helpful
2answers
Ghost printing
You have a worn image drum. The drum is the part of the printer that the print image is created on before it transfers the toner to the paper. This part is coated with a very thin layer of Teflon so the toner does not stick. When it gets worn the toner starts to stick and that produces the shadow or ghost image approximately 3 inches down the page because the diameter of the drum roller is 3 inches. You will need to get the part DR-350, Office Depot has them as well as many places on the internet.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
2helpful
Ghostly effect
If drum is a genuine Brother, then open the rear door and look at the fuser rollers, if you see toner or partial images on the rollers you need a new fuser, if the fuser is clean, look at the drum surface and if you see parts of last print then the drum is bad. In reports, print the user options list it will give the total print count. The fuser is worn out around 80 to 100,000 prints.
2helpful
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Norman Weimar
Norman Weimar
k24674
