2003 Nissan Altima Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vodafone are having probelms fitting a hands free
Vodafone are having problems fitting a hands free kit into a Nissan Almera '53 plate car. AFAIK this is a standard type B radio. Vodafone state that the wiring loom is "different" to that normally used in Almeras and connot identify the correct loom. Did the radio wiring configuration change circa 2003?
m111den
Level 2:
  • Expert 94 Answers
  • Posted on Mar 03, 2010
m111den
Expert
Level 2:
Answers
94
Questions
Helped
54459
Points
191
Hi
normally nissan use a 1 or 2 plug loom, as long as noboby has butchered it to fit aftermarket radio, shouldny have a problem getting a loom. try daltac.co.uk.
hope this helps
How do I remove the radio on my almera Nissan car?
which year
looks like all the radios need some slid down each side of the radio
that releases clips to extract the factory radio
Nissan Almera radio fit
1helpful
I Bought a Second-Hand Nissan Almera, But The Alarm Is Not Working, What Can I Do?
Nissan Almera alarm help??? ' AVForums
www.avforums.com > Forums > Lifestyle Forums > Motoring Forum
Feb 19, 2007 - Last night I went to drive home, switched the alarm off, unlocked the ...Remove negative terminal on battey for 3 minutes to reset your alarm.
How to replace a nissan almera timing chain
Hi all it is with out doubt a major blunder by Nissan to fit a Renault timing chain mechanism to the almera and other Nissan engines. I have dealt with many a customer with an engine light on hoping that a crankshaft sensor would sort the issue out, Nissan will charge in excess of 750 euro to replace the timing kit and having it replaced you might hope to get 120k from the car well I have come across engines only covering 30k buyer chain failure, beware if you are doing a chain replacement your self use (oe) parts often spurious parts don't have the paint marks on the chain to aid setting the timing ,
1helpful
Nissan almera loose clutch pedal
It sounds like the hydraulic clutch is failing or the car just has a light clutch feel. I suggest you have a local shop push the clutch and see what they think.
1helpful
I have a nissan almera 2001 1500 what model
hi i am not 100% sure but i think it is the P11 144 gearbox its used with the almera qg15de engine. i think it is also used in a primera and almera tino of the same years.
1helpful
Blow heater in car not working nissan almera 2.2td dci 53 plate
Hi it is either your blower motor relay or your blower motor itself.
Nissan Almera Tino Right hand side
YEs but if you are going to do some secrifice on your luck of car model from front,
otherwise its impossible,
you can get this from older car dealer or service center,
TNX
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
