Canon PIXMA iP1300 Printer Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After cleaning roller my printer still jam the A4 papers
A4 keep on jam
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
945
Points
7
Check the drum roller if it damaged r check the inner roller teeth if it damaged also it make paper jam
Anonymous
Level 3:
  • Master 712 Answers
Anonymous
Master
Level 3:
Answers
712
Questions
0
Helped
194767
Points
2097
Http://www.ehow.com/how_113761_clear-printer-paper.html
This will help.
When the paper jam in the print
I don't know what make or model printer you are working with but all printers have one thing in common. They all have feed rollers that wear out. If you have cleaned the rollers with simple non-ammonia based glass cleaner and it still jams, time to replace the rollers. If you have replaced the rollers but it still jams, get a stiff piece of plastic the size of letter/A4 paper, remove the paper tray and push the sheet up through the feed roller/registration assembly to force any shards of paper out of the paper path. If it is happening in the fuser area. check the rollers in the fuser to see if they turn freely.
Good luck
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
I had a cannon LBP2900 printer. IT has a problem of paper jam. It prints very well in A5 paper but hen i try to print in A4 paper, the paper gets jam. It also makes some cracking sound and i found some...
Without doing a complete disassemble, remove all covers, remove paper tray(s), remove ink cartridges (or laser cartridges...everything that is EASY to remove. Clean your rollers (may be gummed up a bit), remove all dust, dirt, grime, everything. My Canon printers are extremely sensitive to jams. As long as you keep it clean internally, you should have no problems. Take a look at this video about paper jams.
1helpful
I have a paper jam in the BACK of my HP 3330 and don't know how to get it from aound the cylinder. How do I clear the jam?
Clean the pickup roller with a damp cloth, check whether transfer roller under toner cartrige rotates freely. Check if the size of the loaded paper is the same of the document in the application, i.e. if you print on A4, your document should be set to A4. Sometimes you may receive a document by email with different paper format from what you expect. Reformat the document as setting the page size to your loaded in the printer one.
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
1helpful
When printing paper jams after the second page.
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Paper Jam
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
7helpful
3answers
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
old marine
old marine
ZJ Limited
ZJ Limited
