1997 kawasaki ZX-6R Ninja Logo
Posted on Feb 19, 2010
My 1999 600 wont start smells rich it wants to start but wont also the clutch dose not have to be pulled to start and feels like if it did start it would be in gear without pulling clutch
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3123
Points
22
Rewaork the carb clean it out and the jets as far as the jamming situation wow if it start i gear that simply means it struck in gear or jam un jam it by checking first the cable if not there then next the gear box
Clutch dose not disengage when trying to put it in gear 98 goldwing
Is there air in the clutch line does it feel real spongy or is the clutch plates stuck together and won't release??
Seized engine
Could possibly be Crank shaft, crank bearing, or dropped a valve. Im assuming when you say it wont start, you mean it wont even turn over. If you say the drive sprocket wont turn then someting is stopping the crank shaft from turning. You will need to explore more of the engine to find the exact problem. Workshop manuals can be found online and downloaded if you look about, they will tell you exactly how to strip the engine down.
Smells flooded?
If it is getting too much fuel you should be able to pull a vac hose such as the one to the PCV valve and make the engine speed up.
If it is too rich could be a fuel pressure regulator or injector problem.
Pull the pump relay and see if it starts then runs out of fuel.
I have a 2000 zx2 escort..the clutch feels loose and cud not get in gear..now the gear shifter easly goes into gear but the car will not move..the shifter feels very loose as so does the clutch..could
Sounds like the clutch friction plate was on the way out when you bought the car. The smell you mentioned was probably from the clutch plate slipping.
You need someone knowledgeable to check the linkage is correctly set up and advise if a new clutch plate is required.
The washer has a burn smell what can it be? it fill up with water and would not agitate
Clutch could be locked up see this post Clutch Fix and see if it will get you started to DIY.
There is Service Manual link at that post for the FAV6800A/FAV9800A machines.....Rich
My maytag neptune tl fav6800aw top loader sounds bad and wont spin or drain half the time any ideas were to start. It is about 4 years old
Sorry I missed your post I feel I can help you if you want DIY the fix. From your description it sounds like you have a Clutch malfunction see this post Clutch Fix for support.
Let me know if I can help you thru the issue………Rich
1helpful
2answers
When clutch pedal depressed clutch does not move away from fly wheel started 2 1/2 days ago. is cluth hydraulic or cable? thanks ray
in a car this 'new' prob. hydraulic. check clutch fluid reservoir- should be near brake fluid res.- will be smaller- if fluid is low, or empty- may be clutch master cylinder, or clutch 'slave' cylinder is leaking. check for leak under car, should smell like 'brake' fluid. if your brake master- both reservoirs are to the full line, and there's fluid under car, close to where clutch master is located, or near front of , or side, of tranny- then it's a clutch problem of some kind (as if you didn't already know this!!) relatively new vehicle (by my standards!), should have hydraulic clutch.
do you mean- when you depress the clutch pedal, it goes to the floor, and you can't shift into any gear??
should have asked this first! front wheel drive or rear? i'll guess front wheel drive. may have hyd. fluid leak in master or slave. (apologize for 'terms', but as 'male & female connectors', it's traditional, non-racist and non-sexist nomenclature!!) gotta' be careful, in the 21st century!! if there are, as i stated previously, 2 similar reservoirs, close to each other, then you prob. have hydraulic clutch. may need 'master' rebuilt, or replaced, or 'slave' replaced-it can be rebuilt, but prob not cost effective!
sorry to be 'long-winded/ texted', good luck!
Engine management light came on after cold start speeding and car feels like it is spluttring also smell some burning like clutch
You more than likely have a turbo boost hose leak or vaccum leak, and the burning smell will be the catalyst getting hot from unburned fuel..The car will run very rich with a boost leak.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
