[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect". The solution to this very simple. No software or hard ware changes required. The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise. [u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Most probably you have a problem with the connection between your graphics adapter socket & your monitor. Check this connection & make sure it is not loose & that the cable connecting your computer to the monitor is not damaged or is not running very close to a source of electromagnetic interference.
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
