Watches Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display disappears when Indiglo is pressed
What does it mean when the display disappears when I press the Indiglo light on my Timex Ironman watch?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 19, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813435
Points
13579
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
  • Karlis Lukjanovs
    Karlis Lukjanovs May 03, 2015
    My watch hve the same problem, but my watch have 1 battery! What now?
  • Karlis Lukjanovs
    And light is flashing!
Timex T5K143 Ironman. How do I get a replacement band for the watch please?
Question edited for clarity.
Replacement Watch Bands & Straps
Timex https://www.timex.ca > browse > replacement-straps
Replacement 18mm Resin Strap for Ironman® Essential 10 Full-Size. C$ 15.99. Strap Only StrapOnly. Replacement 20mm Bracelet for Highland Street Gray large.
  • Replacement 20mm Resin Strap for IRONMAN Classic 30 ...
    https://www.timex.ca > Replacement-20mm-Resin-Stra...
    Replacement 12mm Resin Strap for Ironman Essential 10 Mid-Size. C$15.99 ... I had to have a jeweler mill down some of the plastic so the band would fit.
    "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3.1 · ‎8 reviews
Timex Ironman Watch Bands Replacement
Amazon.com https://www.amazon.com > timex-ironman-watch-ban...
5pcs Compatible with Timex Ironman Classic 30 Watch,Ironman Essential 10 Mid-Size Watch Replacement Silicone Band Holder Loops with a Tool to Remove The ...
Replacement Straps for TIMEX IRONMAN Watches
Timex https://www.timex.com > browse > ironman-replaceme...
Replacement 15mm Silicone Strap for Ironman Essential 30 Gray large ... Replacement 18mm Resin Strap Watch for Ironman 100 Lap Modular Black large.
Total Watch Repair https://www.totalwatchrepair.com > collections > timex...
Total Watch Repair sells Timex Ironman Watch Bands and Replacement Straps online. ... Timex Ironman Indiglo Triathlon Shock Black 18mm Rubber Watch Band.
Timex Resin Wristwatch Bands for sale
eBay https://www.ebay.ca > ... > Wristwatch Bands
44 Results ; 14mm Timex Ironman 30 Lap Navy Blue Ladies Replacement Watch Band TX754261T. C $20.28. C $48.76 shipping ; 15mm Timex Ironman Triathlon Blk/Orange ...
The chronograph function on my husband's Timex Ironman Triathlon 30 lap watch disappeared the last time he reset the clock time. How can he find it again?
press hold set button till display blinks, then press mode key till you have display you want then press set key to keep selected display.
Screen is blank when I push the indiglo button
Whenever you push the "indiglo" button and your display goes blank, your battery is almost dead. Get it replaced.
How do I get my indiglo timex watch off military time?
If it is the five button type I have (there are several) you hold "SET" until a field starts flashing. Then hit "MODE" until you see "24-HR" in the display. Hit "LAP/RESET" once and it should display "12-HR". Hit set again and you are done. Also note that timex has all manuals available online for free,searchable by the "module number" you can find on the back plate of your watch. Hope this helps.
3helpful
Eliminate half moon from dial of a Timex Ironman Triathlon watch
You need to hold down the Indiglo button for 4 seconds. The half moon means that night mode is activated, and it will tuirn itself off in 8 hours (which I'm sure you know by know, seeing how it's been 5 years).
http://www.sportswatchinformant.com/timex-ironman-watch-night-mode-feature/
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
2helpful
2answers
Timex Watch
While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
Press the mode or bottom left button until the hour digits start to flash.
Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
