Televison & Video Logo
Posted on Feb 27, 2008
Dynex tv code
Need tv code to program direct tv remote
  • 7 more comments
  • Anonymous Mar 07, 2008
    Code 0490 does not work for me. Several codes allow me to turn the volume up but I can not turn the volume down using the direct tv remote. The mute button also does not work. Any other suggestions out there?
  • MzPhilly Blunt Apr 19, 2008
    THIS BEING A NEW MODEL TV MY DIRECT REMOTE DO NOT HAVE THE CODE & IT SAYS FIND ANOTHER MODEL THATS COMPATIBLE, WHICH MODEL IS COMPATIBLE TO DYNEX?
  • libertyw Jun 24, 2008
    so the direct tv people say that dynex is not supported, is there no solution...?
  • nozhackum Dec 02, 2008
    tv code to program remote control for dish network. Dish does not have a number for this off brand television set.
  • ifd100 Dec 27, 2008
    I need the dynex remote codes to get tv to operate
  • Anonymous Dec 29, 2008
    Which TV is compatible with Dynex, trying to set my Direct TV remote!
  • pbart13 Jan 07, 2009
    I just got a Dynex as a gift with no book or information. I have a direct tv remote that works somewhat but will not turn on or off and the volume does not work. I tried to program the remote with every suggestion and number combination I could find,nothing works. I'm stumped and if anyone has another suggestion I'm willing to try it Thanks,P.
  • Anonymous May 26, 2013
    does anyone kinow how to fix a tv its a dynex it shuts off on its own and pops just before it turns off and then it will turn on a few mins later
  • Anonymous Mar 30, 2014
    I can not program my DIRECT remote to this tv without a tv code.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25759
Points
86
THE CODE FOR DYNEX TV'S USING A DIRECT TV REMOTE IS 10463. THEY ARE AFFILIATED WITH SANSUI. THEY USE THE SAME CODES.
Anonymous
Level 1:
  • Posted on Dec 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25759
Points
20
I have a 26" Dynex LCD TV and the dish remote code for the TV is 720. Hope this helps!
Anonymous
Level 1:
  • Posted on Oct 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25759
Points
15
The code is 10463 to program a Dynex tv with a Direct TV remote.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25759
Points
11
For our Dynex 26" LCD TV, codes 726 and 834 worked on our Dish Network VIP 222k remote.
Anonymous
Level 1:
New Friend:
  • Posted on Sep 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
25759
Points
Try the Insignia codes - Dynex is a re-branded Insignia
Anonymous
Level 1:
  • Posted on Sep 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
25759
Points
Use the codes for orion.
A
Anonymous
Thanks for the dynex website. It is perfect I can use all the functions for the TV with my directtv:)
A
Anonymous
Dynex has codes at their site http://www.dynexproducts.com/universalcontrolcodes.aspx
A
Anonymous
Emerson worked for me. It is the third code after you select Emerson.
4 Related Answers
Anonymous
  • Posted on Jun 17, 2010
SOURCE: dynex code for Charter cable remote
I need the current codes to program my remote control for Dish Network
Anonymous
  • Posted on Aug 03, 2008
SOURCE: Need code to operate Dynex Flatscreen TV on Verizon Fios
The code is 0490
Anonymous
  • Posted on Jul 29, 2008
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
I went to the DYNEX website and found universal remote codes. http://www.dynexproducts.com/universalcontrolcodes.aspx
This fixed my problem between the direct TV remote and my 42 inch DYNEX plasma. There are codes for different models as well.
budlight2k
  • 20 Answers
  • Posted on May 30, 2010
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
2answers
Have F-2100 Universal TV Remote need code for Dynex Television.
But........
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Dynex TV Remote Control Codes
Dynex Products https://www.dynexproducts.com > remote-control-code
Dynex TV Remote Control Codes ; Charter DIGITAL: 0463 ; Comcast M1057: 0463, 10463, 096 ; Cox COX: 0463 ; Direct TV RC23: 10463 ; Dish Network VIP508: 720 ...
Programming Dynex TV Remote Codes [2023]
The Product Analyst https://theproductanalyst.com > Remote Codes
Oct 6, 2022 - 5-Digit Remote Codes for Dynex TV Ā· 10463 Ā· 11463 Ā· 11780 Ā· 11785 Ā· 10180 Ā· 10178 Ā· 10171 Ā· 10623 ...
Remote Control Codes For Dynex TVs
directutor.com https://www.directutor.com > content > remote-control...
The button will blink twice to confirm the code is stored. Dynex tv codes for universal remotes using 5 digit remote codes. 10463 11463, 11780, 11785. Dynex tv ...
codesforuniversalremotes.com https://codesforuniversalremotes.com > remote-control...
Dec 19, 2015 - Remote Control Codes For Dynex TVs Ā· 5 digit remote codes for Dynex TV 10463 11463 11780 11785 Ā· 4 digit remote codes for Dynex TV 0490 0463 0783
2answers
I need Dynex tv codes for universal remote programming
Hello
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
2helpful
2answers
Need all in one remote urc3021 code for dynex tv
Do you mean a One For All URC-3021 remote? The manual and code lists are available here: http://www.oneforall.com/support/manual . Enter Universal Remote and then the model in the drop down menus. The direct link for the URC-3021 manual is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
The Dynex TVs are usually made by LG/Zenith. You can try the Zenith codes: 0017, 0463, 0178, 0092 .
However, universal remotes are usually limited to having only codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
(the URC-3021 remote manual has a 2004 copyright date.)
13helpful
4answers
Try using the codes listed for Orion products. Worked for me.
Find a code to program my direct tv remote
look at the back of tv to see where tv was made,.this will heip me to find you a code
40helpful
10answers
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
