Akai PT46DL10 46" HDTV-Ready Television Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to find a bulb and cage for Akai pt46dl10
Cant find a bulb and cage to go on an Akai 46' tv. Been searching on every website and store and cant seem to find it.
Anonymous
Level 3:
  • Akai Master 5,138 Answers
  • Posted on Feb 18, 2010
Anonymous
Akai Master
Level 3:
Answers
5138
Questions
5
Helped
1004466
Points
13534
If your serial# has J P/N DR150E23
If it has a Z in serial# P/N L920-0017/P306
Mats Electronics 1-800-628-1118
And Go to E-Bay look under Electronics/type in Lamp number.
Replaced old bulb with new bulb (same model), and the TV doesn't turn on. The bulb cage is in, and the back vents are on. For what ever reason the circuit must not be completing because it's not turning...
if the old lamp is still working, try it on just to make sure the new lamp is working, which more than likely it is GOOD. If you hear a clicking, buzzing. you may have a ballast problem. Meaning that this small board is responsible for providing your lamp w/ the correct voltage, and it might not be able to light up your lamp.
Akai tv went blank
if you purchase a nine pin RS-232 connector cable with a male end and a female end you can hook your TV up to your computer. You can actually run a diagnostics program, and tests on your TV! The cable is like 5-10 dollars depending on length and is availible at most local computer stores. Just hook the cable up to the data port beside your PC input on the back of the TV. Good luck! (just saved you 100 tv repairman bill) and also check the bulb to make sure it is still good! The service guide to this TV has ALL the answers to your TV at www.nodevice.com , search in service manual and it has all the codes to reset your tv and counters for the bulb for $10..(for the manual that is you just download it to your computer then print it off)
2answers
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
I need a remote for model # pt46dl10 akai tv lcd 46 in
have same tv searched and tryed alot of universal ones that where supposed to work but did not finnaly found out only logitec harmony 550 universal remote works bought on on craigslist for 65 candian and works perfect with this model
4helpful
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
1helpful
Need to know how to change the lamp what is the procedure
theres a small square on back of tv you need a small torqz screwdriver to take off then bulb is inside theres a cage with bulb to reset lamp push menu on remote then enter 90918988
3answers
Need new Jl amp
DLP LAMP SOURCE. PO BOX 503882 SAN DIEGO CA.92150
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
